1 - 8 of 8 Posts
After countless searches with no real results, I broke down made an account so I could ask my questions and hopefully, finally, get my bike back on the road.
So my bike, a 2003 gsxr750, was running fine and working great for most of the summer. One day, after being stuck in traffic for a good 40 minutes, I pulled over to fill up with gas. When I went to start the bike, this is what happened:
After that day, the bike would start about 50% of the time for about a week. I could never get it to start while it was hot, but it would sometimes start if it had been sitting for awhile.
About a week or two of this, the bike would never start on its own, regardless of how long I let it sit. However, aside from 1 incident, the bike seemed to start with no problem when I push started it. The bike would also start immediately when being jumped.
I took the battery to get tested at autozone and their machine reported that it was a bad battery. So I took the battery to the dealer to cash in on the lifetime-warranty on the battery. They took the battery for a couple hours to charge it and then when they tested it they said the battery was in almost perfect health.
Sure enough, when I put the freshly charged battery back in the bike, it started right up. I rode it on a cool evening on the highway at about 70 mph for 40 minutes or so and then turned it off. I waited about 10 minutes and tried to start it again, no luck.
It then seemed logical to me to assume the battery isn't getting charged. I thought maybe it was a bad rectifier. So I measured the voltage on the battery to be about 12 volts with the bike off and about 14 volts when the bike was on. From what I read though, these are exactly the numbers I'm supposed to be getting.
So, I have no clue. I would greatly appreciate any help or advice anyone has to offer. I would just love to be back on the road with my bike.
Batteries can do strange things - they can show perfect on the multi and be screwed once a load is applied. If you can jump start the bike - swap the battery out.
If another battery goes bad - reg / rectifier should be replaced, as these are notorious on your model for failing...
Si
yup battery. Do what they said above. That's probably it. If not then check the starter, but I doubt that is it.
Well I put a new battery in and that seems to have solved it. I wish you guys would've told me to do that sooner!
I wonder why they tested it as a good battery, could have solved the problem weeks ago if it had tested correctly.
Thanks for the help.
I charged your battery for four hours, and put a multi-meter on it two seconds after the charger was removed and got 12 volts, good battery...
Both Handsome AND Pretty!
^ Unfortunately this times 1000. :hammer
1 - 8 of 8 Posts
About this Discussion
7 Participants
oldfart01
Full Forum Listing
