Just wondering if, on these bikes, one can change swingarm bearings without such things as a press. Do they need to be pressed in, or can they just be banged out and then tapped in? Thanks.
With the swingarm off the bike you might be able to come from the back side with a punch. Use a little heat from a propane torch. If that doesn't work you can always cut them out with a dremel and cut wheel, but ya got to be real careful. I like to freeze a new bearing and heat the the place it goes. Find a socket that fits it exactly and tap it in. I haven't done a swingarm in a long time so I am not sure of this whole job, but this is kinda standard for needle bearings. good luck. BTW, I should have a set of dyno jet needles for 34mm carbs, but I don't have clue where to start looking. If I can find them I will let you know and just send them to ya. No charge.
I would really appreciate that Rogerlee. Your a good guy. And thanks for the info on changing bearings. I changed the swingarm bearings once on a 97 or 98 ZX7R. It was a bitch to say the least. I may just pay someone to do it. Thanks for the info though. I'll send you an email with my address, in the event that you find those needles. Thanks again.
Thats how mine went in.. water cooled bike though.
