OK please bare with me I'm new to working on bikes not to riding them and I just recently purchased an 01 gsxr and when I went to change the spark plugs noticed some unplugged wires here's a link
to the
How do I figure out what codes it's throwing? Is it basically the same as a car and I need a code reader?Looking at the FSM, that generation has an exhaust valve. Makes that "baffler" comment make some sense. Guessing you have a C46 code?
And yes fuel pump primesI think that is the fuel pump plug. Does the fuel pump prime when you switch the key and killswitch on in neutral?
You should get the bike into dealer mode to diagnose the FI code so that you can know what is really wrong. I think for this bike you'd just need a wire/tweezer tips to stick into a plug to get into dealer mode and the dash will tell you the error code.
I am not sure exactly on the specifics of your exact bike's exhaust, but best to not guess and just get the code. Kinda sucks because the FI light can be something as minor as an unplugged sensor or as major as low oil pressure. Figure it out before riding. Hope this helps.
-Mike
Thank you I'm going to do that as soon as I get paid also I don't know if I am hearing things because I normally have a hood on under my helmet and I didn't today and it sounds like a there's a dust storm type sound anytime the engine is reved up I mean it's possible it always made the sound and I never noticed it but now I am worried is it normal to here a shooshing sound"How do I figure out what codes it's throwing?"
Download the service manual. The location on the cluster of things of interest is shown on 7-23. They include the FI light and where "FI" or the FI codes will appear. Information about the codes appears on 4-28. To see the codes instead of "FI" you need a dealer mode switch, about $20-$25. The switch for K1/K2 has a connector with four pins, unlike the six pin connector used on later models. Note that most codes are cleared if you turn off the ignition. The codes are explained later in chapter 4.
