There are people on both sides of the fence on this topic.
First off, the gasket being fresh is uncompressed. Once the engine is reassembled, the gasket is compressed to form a tight seal. When you take the engine back apart you are realigning the gasket not to the orginal position that it was in, even if it a very small difference, there is still a difference.
Even though the engine has not been started, that really doesn't make that much of a difference, so don't let that influence your decision. The real question is what is best for the engine. You would be kicking yourself in the ass if you did reuse the gasket, assembled the bike, started it up, and a day, month, or even a couple months down the road, you realize that there is a rupture in the gasket from it being reused. Then you are stuck in the same position that you are in right now, except with the possiblity of other engine problems from the secondary use of the gasket.
My opinion is that it is best to do a job once correctly, not twice half-assed. I am not saying that reusing the gasket is half assed, just be weary of the situation. Buying another head gasket, and doing the 'right' thing is best. Without looking at the gasket and the surfaces that mate together it is hard to say go or no go. I personally want the best for my bike, and I don't want to be a direct cause of future problems that the engine might have by cutting corners, so I would say new gasket time.
But...
I have to admit, when I have been tight for cash, and in a pinch, I have reused gaskets before with no problems. It was the clutch gasket, where I could see and smell if it was leaking.
If you do decide to reuse it, look at the gasket closely. Inspect it for any compression marks that do not look right. Next, look at the mating surfaces: clean, clean, and clean again. Use a wet stone to smooth the surfaces, take your time. Finally, realize that if there is a problem later on in the life of the engine that is connected to this situation, don't repeat your mistakes!
That's my .02
Good luck
