1 - 8 of 8 Posts
Bought an inexpensive harbor freight plastic welding kit and would like to try my hand at a few repairs. I would need to determine what plastic is used on the 88-92 gsxr models.
Here is whats in my kit. Which should I use?
Contents: (17) Gray PVC Plastic Rods, (17) Green PC PP Rods, (16) White PC ABS Rods
Weldable Material: PVC, PC PP, PC ABS
Thx
Don't know about the late 90's but nowadays the backside of plastic parts has the plastic type molded into it. MEK is useful in repairing ABS. Also search google for "repairing abs motorcycle fairings".
i just purchased a "plastex" repair kit for my damaged oem abs fairings. seems straight-forward, and i need to learn how to fix my own fairings.
Make sure to test it on a discrete area, first.
Discussion Starter #6
Thanks guys. I had heard it should be indicated on the panel but I cannot find anything from back then.
Cost was minimal, so I'm going to give this a shot, but I'll bet I end up covering it with one of the many other repair substance I've used in the past.
Its ABS and the letters are molded into the fairings. Plastifix or plastex is chemical welding and works much better than heat welding; much easier to control and makes for cleaner joints.
i've heard good things about plastex, which is why i ordered it. will try it out in a few weeks.
1 - 8 of 8 Posts
