1 - 2 of 2 Posts
Hi,
I've seen some pics of very early pre-slings with 92' model front fairing. ( see url)
I'd like to know what's involved with such a modification. Is it just custom mounting brackets for the fairing or does the fairing require serious surgery ?
Thanks for all your advice.
TeshOld gixxer with new faring
Not alot of work, suzuki stuff is all fairly interchangeable, I have a 92 1100 with TL1000R body work, mainly if you want to go stock to stock(I have racebody work-easy to work with, check my ost here about my project) you will need the corresponding headlight and headlight/upperfairing bracket, as far as the side pieces go, some fitting might be required, which is why I went with http://www.sharkskinz.com
drill your own holes etc.
-Karl
1 - 2 of 2 Posts
