Discussion Starter · #2 ·
Re: can a \'01 \'02 oil cooler fit on a \'03 \'04?
com'on guys...i really need help.
Would those who know abt this pls help?
I don't know but if your interested i have one off an 04 1000. If interested pm me.
I haven got the chance to put the oil coolers of the 2 yrs side by side to compare.
But my concern is do they use the same oil cooler hoses?
Are the inlet and outlet of the coolers in the same orientation?
yes they are the exact same. the only difference is that the brace that's on the bottom of the oil cooler that connects to the engine, the black grommet that the screw goes through is connected to the radiator on the 01-02 (a welded on tab on the bottom) and on the 03-04 it is attached to the bracket that connects to the engine. Very easy to just dremmel that bracket off the oil cooler though since you will have 2 of them. if your putting an 03-04 radiator on an 01-02 then you may have to do without it.
Discussion Starter · #7 ·
Appreciate your help on this!!!
PS : Your siggy is juz the exact opposite. =)
