1 - 2 of 2 Posts
Having checked the valves on my '95 750r for the first time I need to know this:
-Is it possible to take out the camchain tensioner without having to remove the carbs?
I need to remove the camchain tensioner to be able to put on the camchain again, right? 'Cause it's dawn tight.
I think it's tight but you ought to be able to get in there with a open end wrench. Just don't loose any springs or tiny bits in there.Do you have a diagram of that tensioner like the one in the Fact manual?
just curious, what special tools did you use to do the valve check.
I've got a used head to install but I'd like to check the clearances myself if I can do it right.
thanks
EDGE_
1 - 2 of 2 Posts
