1 - 17 of 17 Posts
Has anybody came up with a home brew kit???? I've searched and everthing pointed to the APE kit. I can't see paying $300 for something I can make out of ss lines and fittings.
Where do I take the feed from? I've seen some that come from the bottom sides of the motor and some that come from the allen bolt on the side of the valve cover, which one is which????
Cheers
[ 12-10-2002, 08:08 PM: Message edited by: fightin-ry ]
The oil feeds from the allen bolts on the valve cover to the rocker shafts. It's probably not something you can make look as clean as the APE kit. We use them alot and the quality is first rate and they will help solve the rocker arm wear that we all have to put with. You can also get these from Schnitz Racing. I think the price may be a little better.
Originally posted by Mr Gixxer:
don't trust that guys bike! it takes 20 liters of oil
<font size="2" face="Verdana, Arial">...I think he's ignoring us...
BTW... I sent copies of these to Bones... I saw the new moderator's R's and made these for any oldskoolers who want `em
...or white BG if ya think that looks better...
[ 12-11-2002, 01:11 AM: Message edited by: FastCat ]
YAAFM Mod
The one advantage to the kit is that the rear head fitting is tapped for the mid fairing mount. I have seen home brewed kits before using aircraft fittings with the banjo bolt re-threaded to metric. This is one of those things that I would just break down and by.
Bones
i can put together something for you guys on that same top end oiler that ed has pictured above...give me a show of hands by way of email and i will get you guys a great price on this kit...thanks..
dwayne
hey ed thanks for that plug over on the bandit board...i have two guys so far...guys let me know if you want this...i will hook you up with a great price but need to know for sure who's in...thanks..
dwayne
Posted: Dec 11 2002, 10:05 PM
Group: Members
QUOTE (FastLarry @ Dec 11 2002, 10:40 AM)
How much are guys paying for the top end oilers Ed, I got mine from S&K Cycle in Dayton Ohio for $226.00 delievered.... FL
we will beat that price...haven't talked to carolina cycle on this deal yet but doing business for years and we can make this happen...we will sell at cost if we have to just to show you guys that we will give great prices...thanks..
dwayne
Cycle Concepts-High Performance Specialists
1625 Lynwood Dr
Lancaster,SC 29720
803.285.8093
__________________________________________________
I will take one for cost
<font size="2" face="Verdana, Arial">Hey, I only 'borrowed' the first 10 from your stash! Sheeeesh
Yeah, I didn't go for the Earl's cam oil link kit (Earl's UK) because it was 10mm (oilers) vs 8mm (water pumper 1100's). Earl's (and mine) take the oil from the high pressure galley feed (lower). Don't know the oiler internals as to where the top to top feed is from...would that be from the cooler pump feed?
Discussion Starter · #16 ·
I'd get in on the deal too but, $230 USD is 7 G's CDN
I should be able to put one together for $150-200 CDN, I hope.
The only place I've found to get the banjo's at is Earl's UK. Is there any other place??
1 - 17 of 17 Posts
