you're trying to do the pair removal mod? it has wires right? you most likely have to deal with them, maybe an inline resistor? the ECU is expecting a signal from the pair valve, whats it get when you remove the valve?
my guess is if you trouble shoot the pair valve the manual will give you the value the ECU is looking for? has to be someone who's done this, prolly be like 15 ohm 10 watt resistor something like that? solder it in and heat shrink wrap it a few layers, tuck it away where it wont get wet or melt?
