Hi guys,i bought my bike with an aftermarket Yoshimura exhaust on it. every OTHER time i start it it runs a C00 Code.
then one time i caught it with a C46 code, i think this is the one that keeps setting it off.
i know there are alot of topics on this about the exhaust valve. I'm so confused about it though. i read somewhere you need to put more voltage to other wires or whatever is this true?
or can i just open the exhaust valve manually, unplug the two plugs, and take out the #30 wire or whatever it is, ( gotta look up the wire again).
Do i have the right idea?
Well for starters a C00 code is nothing. That is normal operation, however the other.. On the K7's I believe I read somewhere that the Exhaust is default open, although I could be wrong. If you do remove it, you should install a servo buddy instead of just clipping or jumping wires.
