So i have a 2011 GSXR 1000. i put a full yosh exhaust and bazzaz on it now i have c34. i removed the bazzaz, but the c34 is still showing. Please help. Also is there anywhere i can DL maps for my bazzaz
c34 is an injector code, but could also be related to the fuel pump.
Check the fuel pump flow rate, and the strainer to make sure it isn't clogged.
Make sure all your connections are secure, it is easy to think you pushed a connector together and have it still be loose. Make sure you hear the click of the clip when you push them together.
Could also mean the injector duty cycle is too high, but if you pulled the Bazzaz and it still came up, I doubt that is the issue.
Get yourself a copy of the factory service manual, it will explain the process in detail.
