I think this one or run by pulley
If so check it's tension, put into dealer and check the mark
Sent from my Redmi Note 9 Pro using Tapatalk
Thanks for ur reply, but i dont understand what u mean. Could you try to reformulate what you're saying please?I think this one or run by pulley
Hey! thanks for the reply. I see. Any suggestions for what i should do with the problem? any point in buying a new STVA for example? what about removing the valves?The squealing you hear is the fuel pump. The service manual has testing procedures for the STVA. C28 tells you what system has the problem, not the specific component in the system. Based on the way it's moving, I think the secondary throttle position sensor is suspect. Sometimes they short internally and fool the ECM into thinking the STVA is moving erratically when in fact it's just bad data. The ECM just doesn't know the difference.
However, that STVA is a one off and was only ever used on the 2003 600. It's a bit of a goofy design compared to all of the other STVA designs.
Yes remove the secondary butterflies. If I remember correctly they font sell parts separately. Choice is to get new or used throttle body. Removing the secondary butterflies can make a few more HP top end but may produce a small flat spot on the bottom end. If you have a tuner I suggest cleaning the fuel map up after removal.Hey! thanks for the reply. I see. Any suggestions for what i should do with the problem? any point in buying a new STVA for example? what about removing the valves?
