Does anyone Have a fix for this, I've done all the appropriate checks per the service manual and I keep getting this damn code...The bike has less than 1500 miles on it. I talked to the dealer and they stated they would have to solder something in there to keep the secondaries open, is this the only fix? or can a flashed ECU work this out?:dunno
What coil resitances did you get? What happened when you put it in active control? Have you measured the secondary sensor voltages and resistances?
Tell the dealer to honor the warranty or call the federal trade commission.
When the dealer tells you that you installed a bazzaz and voided your warranty, simply say "Per the Magnuson-Moss Warranty Protection Act, I'm demanding that you prove my aftermarket fuel controller caused this failure. If you refuse, I must inform you that I will file a formal complaint with the Federal Trade Commission".
