May or may not get a reply on such an old post, why dont you DM BillV he is always happy to help ?
May or may not get a reply on such an old post, why dont you DM BillV he is always happy to help ?more info on this please
I really appreciate it man thanksI'm fairly sure that the pics were originally posted on Tinypic and they've shut down. I've since put everything into a doc file. As I recall T.R.E contacted me via PM and the file may also contain some comments to him. Give me a day or so and I'll copy it to a place that it can be downloaded from.
what wires do I tap into to get it to work right. does the stock light still work in sync with the led?
He I really like your set up I was just gonna go with a red led strip across the lower portion of the windscreen.The OEM light is unaffected. It's on in the pic but not immediately noticeable because it's so much dimmer than the new light. The new light dims with the cluster setup intensity setting but I don't claim that it exactly follows the OEM light. It could probably be fine tuned with the resistor values. I just wanted a more noticeable light and was happy with what I have.
I wish that the cluster had a larger range and finer increments on the trigger RPM setup as it could then alternately be used as a speed (meaning MPH) warning indicator. Unfortunately the RPM in 6th gear for 70 MPH is around 4650 RPM and, as I recall, that's lower than the lowest setting. I've been looking onto what reprogramming is possible on the cluster but this doesn't seem to be one of them.
so you tap into the board of the cluster and mounted the red led in it?An advantage of mine is that it's all part of the cluster so you don't have to worry about leads running off somewhere and the associated connectors.
