Hi,
The other day I removed my tank to check the internal strainer at the fuel pump. When I was at it I checked the two hoses hanging under the tank. The larger one was totally clogged and didn't let any air through but after some cleaning it opened up. My question is what is the function of these hoses? Both inlets are up by the fuel cap but outside the sealing rubber grommet so I do not really understand why there are two. If one of them somehow ended up inside the tank it could prevent vacuum in tank but since both are outside sealing rubber it's not the case. Hope my question is clear enough to be able to answer
