I rebuilt my front brake caliper Because it was gunked up with fork fluid now can’t get pressure at master cylinder have had numerous attempts with Miti vac Bleeder what could b wrong swaped master cylinder and same result
Write hole process of rebuild. Maybe some mistake in rebulid will be found.
"front brake caliper ... was gunked up with fork fluid"
Huh? How did that happen?
Is the M/C the OEM or the recall replacement?
Read through the first page of this.
