Hello again guys,
I'm fiddling around with my brakes in order to optimise them but i'm far from it.
My setup currently is:
Brembo Rcs19 master cylinder
Venhill Braided lines
Motul Rbf 700 brake fluid
Tokico standard brake calipers
Suzuki standard brake rotors
Brembo SR pads.
My issues are:
A) Too much of empty space before the brake lever begin to grab. It's almost 1/3 of the full length (If needed i will provide photos)
B)Almost none initial bite.What i mean is that when i press the lever (2/3 of the length due to problem 1) i can feel that the brakes grab but i don't slow down. In order to slow down i will have to put a lot of force (not 3 fingers force, still 2 but u get the point) and then they work as expected. There are no brake stucks, no sudden changes in the grabing force, they work as expected. Also temperature doesn't play any role, i have the same situation with cold brakes and hot brakes.Also there are weird patterns on the brake disc, like "white dots".(Can provide photos if needed).
What i have done/ checked.
A)Already done multiple bleedings-Seems to work for a couple of kms then its the same
B)Cleaned my calipers without putting out the pistons, checked for leaks, no sign of leaks,the pistons move freely and no issues with different pressure from side to side.
C) Cleaned my brake discs with scotch bride and brake cleaner,also cleaned (kind of) the brake floaters (i don't know the name)- the thing that keep the outer part conected with the inner part, like small discs.
D)Checked if pads are touching the discs, i have over 1,5 turn of the rim, no issue there.
E)Checked for leaks in the system, nothing
F)My mechanic didn't find anything unusual
G)Used both settings in the master cylinder (20/19?), none worked as i would like to.
I'm out of ideas, and the issue is that with that much of a traveling distance in the lever, i have to "prime"my brakes before each corner.
What can i do more?
Brembo SR pads.
My issues are:
What can i do more?
