Howdy,
I rebuilt my front brake calipers. I cleaned (and kept) the pistons and replaced the seals. Then I put them back on the bike, used a vacuum tool to get the brake fluid flowing again through the lines, and ever since then I've been using the zip-tie-on-the-brake-lever-overnight trick to get residual air out. So far, so good. The problem is the bubbles keep coming out! Big bubbles. I've gone through about 20 zip ties this way. All I can think of is I let the reservoir get too low (I thought I was being careful) and it sucked major air into the lines. But I've been bleeding air for so long that any residual air should have been long gone. Has anyone had this happen before? Any suggestions?
