Hey all so I’m in the process of bleeding my brakes started at the master went to the right side both getting fluid went to the left side no fluid coming out tips suggestions??? Tia
The master cylinder should be last, it's the high point and you're using it to release any trapped air. Start with the right side, then the left side, and finally the master.
furthest away from master first, then closest then master, if you are not getting fluid com1ng out of one line something is clearly clogged up, blow it our with air and inspect real well, any hint of damage,wear or degradation opt for brand new, never risk front brakes on a sportbike, that's your lifeline
so the line was clogged i thanks for the help ride safe
