I've looked at many threads already but for some reason I just haven't gotten the hang of blipping downshifts yet. Perhaps my technique is off?
So if I have this right, I should simultaneously (if not, then what order?):
1. Pull in clutch lever
2. Downshift
3. "Blip" the throttle to about 1-1.5k RPM higher
And then
4. Release the clutch lever.
Is this right?
As far as what "blipping" actually means and the timing of the clutch lever release, should I:
A. quickly increase the throttle 1-1.5k RPM, release/return the throttle back down, and THEN release the clutch lever as the throttle has already begun going down.
B. quickly increase the throttle 1-1.5k RPM, and THEN release the clutch lever at the height of the throttle raise essentially beginning the return of the throttle while in gear.
I thought the correct method was A but I feel incredibly slow or my timing is off compared to some videos I've seen which actually looks like maybe its method B.
Example:
2. Downshift
And then
Is this right?
Example:
