2009 gsxr 1000 with 5k miles.
Bike started up and took out for ride. Runs like a raped ape after 4k rpms with no hesitation stumbling etc.
At idle the bike runs lumpy and bounces around between 1k-1300 rpms. It is also hesitant up to 4k and stumbles around but clears up after that.
I came to a stop a few times and the bike will die out of nowhere. There are no FI lights displayed.
Now bike will only idle less than a minute before stalling. It will start right back up and run fine if you keep the revs up.
Never had these issues before except for a slightly bouncy idle from the yosh and bmc filter on a pc5 base map but never stalled or died like this.
Changed oil and filter a few weeks back. Ran the old gas from winter out and filled with fresh 93. No vac or fuel lines are loose under the tank. All connectors are tight. Where do I start?
Plugs fouled? Bad cell in battery?
