1 - 14 of 14 Posts
I have a question as i can see Bike is Much more faster and can feel acceleration at night than day. Whats the reason ? I mean at night temperature is lower and thats reason but . I am asking faster becouse that farenheits in cooling system is lower ? Or becouse of AFR or whats the reason ?
Hand-Eye Coordinator
A lot of variables with engine performance, but there could be a few things that are night and day. :lol
1. Temperature. Cold air is more dense.
2. Most likely, you live in a very humid place and when it gets cold at night, the temp falls below the dew point- meaning the water vapor in the air falls out. In places at 35 celsius and over 90% humidity cool to 20 degrees, even though humidity remains at 90%, the actual volume of water in the air decreases by well over 50%.
3. Check your air filter and Intake Air sensor for dirt. This may be making issues worse.
The reason my bike is SLOWER at night is because due to lower light and less visibility I don't twist the throttle as much.
Super Moderator
Nighttime and colder months are good for at least 3-5 ft/lbs of torque I swear. :banana
Could it be that there is less traffic and so you open the throttle more?
Ex-Lady Supermod
It's the same reason 2 air crafts of equal weight in hot Summer will need more runway than in cold Winter. Air is more dense when cold than when hot, so the ram air/engine is getting more air and the cool air keeps engine heat down, heat robs HP. I haven't noticed this effect on my K8 750 but certainly feel a difference in my ram air car, according to my butt dyno.
Discussion Starter #7
Absolutly right , you can feel huge differance in cold weather , and is there any way to install somthing to send cold air in engine even in hot days to have great performance when racing or going on drag ? I mean some kind of trick or somthing to install in intakrs or airbox for cooling air more than stock
Ex-Lady Supermod
You could try filling your air box with dry ice? Back in the day when I had an intercooled turbo Mustang, I was told to put ice on the intercooler for performance gain, of course I never tried it.
What are you using for data recording?
1 - 14 of 14 Posts
