my gsxr 750 doesnt move when in gear.i can start the bike fine by pulling in clutch which is a must with these bikes but when i put the bike in 1st, bike only revs but doesnt move.same as with the other 5 gears.i can upshift and down shift through all the gears but bike never moves but it will stutter like normal if i dnt pull clutch in when the bike is in gear and not being givin gas jus as if im riding except for the bike is staionary.
i was thinking maybe the clutch was burned. as i checked the oil through the sight, it was normal looking.no white resedue or anything.
i had a guy start the process of replacing the clutch inwhich the oil had to be drained.when the oil was drained, he said there were shavings on the magnet and also in his words "chunks" of metal in the oil but color of the metal was undetermined do to them being covered in oil.also he said there is a little color of white mixed into the oil. WHAT MAY THIS BE AND WHAT IS WORSE CASE SCENARIO? he told me right away it was the transmission. oh and i am able to push bike around with no problem or weird noises.
