I don’t know too much, just learning my own bike also. Try adjusting the clutch cable on the handlebars OR while the clutch is pulled in, slowly let out while hitting the start button. Maybe something just as simple as that.
Don't think it's an issue with the clutch switch, but thanks for the suggestion. Everything seems tight and working as it should be there.
Two things. 1) Can you push start it? 2) How old is the battery?
The battery is brand new, but I put the multimeter across it and it's flat as! Got in on charge now. Haven't tried to push start it, I live on a steep hill and I could obviously roll it down but if it didn't start it's quite a push to get it back up again.
Has this question ever been asked before
Yes it has mate. Thanks for your helpful input. I have read the forums and done some searches and am doing what has been suggested before now, but it doesn't hurt to make a post and ask as well.
Battery. 12.7v. You will need a multi meter. Buy the best one you can afford.
Thanks! Checked the battery with the multimeter, it's flat, reading 11.5v
Have got it on charge now.
The reason I wasn't sure about the battery being flat or not is because the tow/repair guy tried to jump the bike and could not, and he said he didn't think it was a battery issue.
I will take that as heresy and check for myself in future.
Have got the battery on charge now and will see what happens when it's fully charged.
Thanks for all the help guys, appreciate the responses to a pretty novice question that I am sure gets asked all the time.
