Bike was in a wreck. Low sided then tumbled a few times. Got the bike from a friend and am now fixing up. At first bike was leaking oil and blowing alot of smoke when we first started bike. Ran the bike and oil was burnt off. Then bike was unstable at idle when we started bike. Bike would not hold idle and would shut off. Looked at sparkplug and alot of carbon build up on the tip, tip was black.
I changed the sparkplugs and the fuel pump. Bike starts right up and idle is not as unstable as before. the bike is still burning alot of fuel and alot of black smoke is still coming out. On the idle bike is running rich with black smoke and smell of gas in present. When i turn the throttle a big puff of black smoke comes out and can still smell gas. Looked at the sparkplugs and carbon build up is on the tip of the sparkplugs again. Is it possible if the PowerCommander got damaged or altered the map setting and made the bike run rich? Any ideas why bike is still running rich? Fuel rail is damage, PC damaged, engine damaged, & etc?
