I dropped my bike for the first time today. No big deal. But then when i restarted it it would continue to stall, so i pulled over and let it rest for a few minutes. After i restarted it it idled fine but when i got out of first gear into second and third the bike would lose power and buck and the rpm would drop. if i held the throttle open it would eventually gain power and i could move into third gear where i would have the same problem.
Is this an issue when the drop? Did i flood the engine? Or is it possible there is air in the lines from the drop that will work itself out? I'm worried.
95 Suzuki GSXR-750
Yeah, Chivers, mine does something similar after being dropped. Perusing these forums, I'm learning quickly that its a common result. Many are saying carb gunk gets dislodged and the floats need drained/cleaned etc. also saying to check for vacuum lines that could have broke free and check for excessive oil in the air filter. Ill be implementing those suggestions in the morning and post my findings.
