man I wish I had the dough for a kevlar tank, stainless? aluminum? right now 600 has Ethanol free in it and I have plugged the exhaust tip and blocked ram air inlets, WORKS
the fuel isn't evaporating out of the floats I know this cuz it fires right up after sitting 2 weeks, before plugging off and E free gas, 1 week and the float bowls are dry and I have to use all of the battery priming those carbs again, even having to put the charger on it cuz it drains priming those carbs..
huge relief knowing those carbs aren't drying up or having to start it every 4 days just to keep em primed and everything wet..
600 has so many new OEM parts, all sorts of stuff, basically everything is new, cables, all hoses, brakes, chain sprox, cushy new grips, clock bezel, fuel pump, plugs oil filter, tires, bearings, many new bolts grommets and fasteners, sourced all clips and brackets, its clean.. sure I have at least $2k in receipts if not more? its as complete as the day it came off the floor save the paperwork, looking for that if anyone has it, I have the tool kit and new strap but really would like to have the owners manual to complete it..
having the manual might motivate me to go ahead and buy that decal kit and paint the bike in a good stock color graphics? yellow black looks easiest, then maybe do the 750? I have a new spray kit, just need oilless compressor and rig up a small station, visqueen and a PVC frame, toss a couple heppa filters in front of a couple fans and call it good, point em outside.. just do it! uh huh...
600 really needs a 750 front end IMHO, its not horrible, but its not good either, works... but it is a hard ride compared to Busa, vibration is almost nil tho and that helps eliminate wrist pump and arm pump, it was bad but syncing and dialing in the carbs really smoothed things out plus I use the big heavy bar ends off Hayabusa's, they are heavy and large, absorb a lot of that fine vibration that tends to leave your hands all tingly after a few hunnerd miles..
with risers and a tall bubble I would have no issues taking this bike on 400+ mile a day rides, specially with weight matched 750 suspension set on the soft "touring" side of the dials...
I put genmar risers on the Busa what a difference, easier on the back, wrists, arms, and elbows..
got to empty that 750 tank and get into that... then the frame and swingarm... pretty sure I have more of that bike than I had of the 600.. its almost complete just ugly, sat outside in weather and sun got real faded has like chemical stains on it?... guess I'll find a shop maybe they do it all strip prep and powder coating? knowing I can fill it up with E free and not worrying about water is big, real burnt out on dealing with rust and gel, destroyed fuel systems... this will be the 5th time... however I imagine once its up and running good as the 600 its going to be my go to bike? Busa is just to big and bulky for those small jaunts to store and what not.. keep the 750 right next to the door, BOOM!
last a ran the 750 it ran real good, sorted the clutch sensor and some wiring as in a new right side control the starter works every time, then it just needed a R/R, went mosfet.. its all wired in all about to come out so I can do the frame and swingarm, gonna go through this one same way, new everything, cables, hoses, all rubber save the ram air boots those are good, look new actually.. but I'll go all new bearings, headstock tapered, swingarm, wheels, maybe even repair the Marcesini 5 spokes and toss em on there after a good paint or powder coating?
where can I get Marchesini bushings and spacers for the SRAD?
