try contacting APE [site sponsors] they are helpfull i've never read any info on how they go about it
try contacting APE [site sponsors] they are helpfull i've never read any info on how they go about itHi, i´m planning on putting a big block in my engine (want to go to 1317ccm), and read and heard about sweeping big blocks.
I thought of closing the oil jets below the block, and take off the oil from the crank gallery, and route it through external braided lines up to the head.
Has anyone done this before ?
What size of oil line should i use ?
Are the standard banjos you take for brake lines sufficient for oil flow and pressure ?
Will i need restrictors to keep the crank lubed ?
Yup, but they are a pain to make....your choice, the kits sell for like $230 US......something like that....Hi, i´m planning on putting a big block in my engine (want to go to 1317ccm), and read and heard about sweeping big blocks.
where do you get the kits ragnar? and where's your avaitor been the last couple of weeks???Yup, but they are a pain to make....your choice, the kits sell for like $230 US......something like that....
I'll dig up some more info tomorrow....
A lot of people use these even if they don't block the passages and go with a smaller bore, but i think that's how they got started........
any info will be highly appreciatedYup, but they are a pain to make....your choice, the kits sell for like $230 US......something like that....
Thailand, I can't get enough of that placewhere do you get the kits ragnar? and where's your avaitor been the last couple of weeks???![]()
no, there´s two differnt jets.don't the oil jets under the block spray up under pistons to keep them cool i was looking at my manual today oil going everywhere
eek whats the idea of running more pressure oil to top end?
:scratch:confused
thanks fjd ,i know a bit about the old gs's, i'm still learning on these :cheers kenno, there´s two differnt jets.
The ones will spray oil on the underside of the pistons to cool them.
The other ones will let a measured amount of oil go up to the cylinder head through the holes in the block where the studs are.
What i want to do is keep the oil out of the cylinder block, to avoid the base and head gaskets getting leaking.
For large bore blocks they use o'ringsso you never heard of leaking/sweeping big block engines ?
Especially for road use i really want to avoid any pressurized oil on the gasket surfaces.
i know that, but they are used only on top to help cure blowing head gaskets, what i am looking to avoid is oil leakage.For large bore blocks they use o'rings![]()
Uh...because it was from 2001, the same topic as this as I understand it, the problems of [email protected] are thankfully gone, and I don't like looking at the same thing for 6 years.i know that, but they are used only on top to help cure blowing head gaskets, what i am looking to avoid is oil leakage.
BTW: why did you close the thread on modifications to the top end oiling improvements where [email protected] was talking about easy modifications to improve head cooling ?
