Pukey
We all know our bikes run hot in the summer, especially in stop and go traffic. Is there a better coolant than the OEM that you can recommend.
[ 11-17-2001: Message edited by: God ]</p>
Apparently, distilled water dissipates heat at a higher rate than antifreeze. The only drawback is that it freezes. I run distilled water and Redline Water Wetter.
pure water also has a lower boiling point than an antifreeze mixture (or water wetter)....even with the pressurization. pure water also doesn't have the anti-corrosion additives that antifreeze has, and also doesn't have additives in it to help lubricate the water pump.
i wouldn't recommend the use of pure water in a streetbike. for the track, it'll work fine.
water wetter and evans npg coolant seem to work well....
[ 07-03-2001: Message edited by: jeff ]
