what do you guys think is the best ?
I,m looking at carbtune .£52 ( $90 )
www.carbtune.com
[ 01-12-2002: Message edited by: Jon T. Flesh ]</p>
The best one I've ever used was a Suzuki made unit. It was a while ago and they probably have something better out now.
It took a bit more time because you had to set up the gauge everytime, but it was really accurate. And used a little ball rather than merc.
I've seen guys rev a bike too high and chop the throttle sucking mercury into the motor. Yeah you've got to be a bit of goof ball, but I've seen it done. I seen to remember it cost about $300 though, not cheap.
I currently use my ancient MotionPro setup(uses that dreaded mercury, but I've used it for the past 15 years), but after reading the carbtune reviews the carbtune device looks like a winner. The use of stainless steel cylinders eliminates the need for mercury and is similar in action to the steel ball method that the factory Suzuki gauges use.
Carbtunes are ace - the ones with the steel tubes are superb.
Recommended over any dial type I've ever tried - wether adjustably damped or not.
+1 on the Carb-tune, you dont have to fiddle with mercury, and they are pretty accurate.
