1 - 2 of 2 Posts
Ive got a sidecar with a 2001 gsx r 1000 and i wont to get rid of the sidestand switch the ignition and clutch leaver switch . Im having problems finding the right bike on you tube can someone give me the heads up thanks baldy
Don't understand about the sidestand switch. Do you not know where it is? The service manual should help with where it is and, via the wiring diagram, what color wires run to it. Most people buy a mating connector that has a jumper. But to do it in the same manner as Suzuki, you should be jumpering with a diode. Something like a 1N4002 or higher. See the wiring diagram.
The clutch switch is more complicated. You can bypass it but the ECM will know and will limit your peak RPM. Generally not recommended.
1 - 2 of 2 Posts
About this Discussion
1 Reply
2 Participants
BillV
Full Forum Listing
