Hi guys,
Got a question for you guys as the title suggests i want to remove my balancer shaft completel,y then have the crank gear removed and the crank balanced etc, i am then going to have the alloy portion of the casings that supports the shaft completly cut off and plated up thus allowing more room for my turbo to sit in and up, is this a hair brain idea or is this a feasable modification a bit of input would be much appreciated from you guys.
