lockhart-philips has a wide selection of dampers,check their web site or even ebaymotors.com
YAAFM Mod
Stock damper was 160mm. A 150 will work (that is whats on all of mine) and you can find the fork clamps from ebay, Harris, Lockhart Phillips, Storz, etc. For the fram bracket I like the stock one but you can make from Aluminum angle and use the stock mount holes on the underside of the frame. Ohlins dampers go on ebay regularly (R1/R6 used a 150mm).
