1 - 2 of 2 Posts
Anyone know how to set the minimum RPM which the shifter will function? I used the software provided but all it allowed me to do is enable or disable the shifter itself. I should be able to set the minimum RPM that I want the shifter to work. I want it set at 5500 but don't know how. Any help? Thanks
You use the software to enable it.
Then go back into the normal Powercommander software and go into the options where the trim, accel pump etc are and the "shift kill" will be an option.
Click on it and you'll see how to set min RPM and kill time.
1 - 2 of 2 Posts
