1 - 9 of 9 Posts
Of course I didn't realize that the clutch is connected to that switch assembly and you cant start the bike if it is disconnected until after I disconnected it. Has anyone here removed that left side switch assembly? Is it a bad idea? How do I get around the clutch thing?
Thanks
Don't do it.
For some reason it reverts the ecm to a safety map 10hp lower then stock.
If you do cut it, put an on/off switch in it's place.
true but only on the 05 and up 1000 and the 06 and up 600/750
I just cut the all but the clutch wires out of the harness down at the next connector. On the 06 it is just above the radiator. That way it is still hooked up with the OEM harness, and still in the heat shrink tubing, but all the other garbage is gone.
I bypassed it on my 05 600, then cut the wire back at the ECM. This way the starter relay sees the circuit as closed and the ECU sees it as open.
I'm having the same problem. I disconected those wires not realizing that you can't start the bike without them. Unfortunately I seem to have lost the wires. Do I need to buy a new one? If so where would I get something like that?
1 - 9 of 9 Posts
About this Discussion
6 Participants
WJGSXR
Full Forum Listing
