I wanted to know how difficult it would be to cut the fairing since the two fairing seems to meet where the hole would be. Pictures would help to.
Thanks
Thanks
you need only drill one side of your faring. no other modification. in fact i jus did one for my customer few days back. a hand drill wil do the job, start with asmall hole from the bolting area. use the screw as a guide linejunglicious said:I'm sorry, Its a 06 750. I figure since this is the 06 600/750 section I didn't need to put down the year and model. If you can get pictures or ask him how it was to cut the fairings that would be great.
zord said:you need only drill one side of your faring. no other modification. in fact i jus did one for my customer few days back. a hand drill wil do the job, start with asmall hole from the bolting area. use the screw as a guide line
Anti-sieze doesn't prevent cross threading. It's a thread lubricant. It also affects the torque you apply.socalcoyote said:J) Apply a light coating of anti-seize to each bolt before installl each bolt by HAND to prevent cross threading, and torque to 39 lbs.
I never said anti-seize prevents cross threading. Rather I specifcally said (in caps) to install each bolt by HAND to prevent cross threading. The anti-seize is not for cross threading, installing by HAND is....greygti said:Anti-sieze doesn't prevent cross threading. It's a thread lubricant. It also affects the torque you apply.
Great instructions otherwise. I just don't want someone to cross thread the bolt and come in here and say "I used anti-sieze like the coyote said and I still cross threaded the bolt. WTF?!?!" :cheers
No biggie, as each bike is different when it comes to frame slider installation. You do cut through both, but not all the way if that makes any sense. If you follow my directions (using the exact size hole saw and finish it off with a dremel tool) there will not be an issue with the fairing pieces. Personally I think Suzuki should have thought about frame sliders when designing the new model. But apparently their R&D money went elsewhere....junglicious said:thanks for the info. I did the search and blah blah blah, trust me this isn't the first forum I been on and isn't the first time I put on cut sliders... My main question was do you cut through both of the two piece fairing and if so how difficult is it or how would you do it because I wanted to make sure i wouldn't be missing something or mess it up.
