I moved back to the area about 9 months ago. My Gixxer is acting up and I cant find the problem. It misses in the mid and high revs. I tested the signal generater,the coils, put new plugs in, adjusted the needles in the carbs, adjusted the float height, put new o-rings on the float valves, and swore @ it a few times and nothing seemed to help. I had an awesome mechanic when I was in St. Louis, but I dont know any around here. The only shop that seems half descent is Tom's Cycles in Indiana, but some of the mechanics that I have talked to didnt seem to be very well versed in diagnosing problems.
I was actually in school in Johnstown, and am now in Somerset working.
You might check out Meyers Performance on the top of Ohio St. in Johnstown.
Send me a message if you want some more help finding the shop, and good luck getting it fixed.
I ended up just taking it to Tom's in town. The first guy that I talked to seemed like kind of a jerk, but turnedout to be ok. And the guy that is doing the work is pretty cool. It turned out to be a cracked throttle position sensor. Should be done soon.
