If you don't have any symptoms which suggest other problems (like foam or oil in the coolant), then I would just ride it again a few times before panicking.
All cooling systems have a "natural" fluid level, which normally should be between the high and low marker levels on the expansion tank, but it is not uncommon for them to settle "somewhere close". If you keep adding more fluid, it will keep spitting it out when hot, but if you don't add more, it should just stay where it settled last time out.
Just check that it doesn't spit more out next time, and the engine temp doesn't go above what you are seeing now (which are not worrying).
I have a 750K5 and myine holds a level nearer to the minimum line than to a midway point.
