Re: Any problems with putting a \'91 motor into an \'86 frame?
You have to swap over your oil pan & pick up, also the generator pick up coil. The carbs would be a plus or you will need to swap the intake manifolds.
The clutch Hyd/Cable conversion is very easy, the cable is the way to go.
Mike
Mike
