Hi all, today I purchased my first gixxer 750k8 I traveled 3 hours to collect bought with confidence after a test ride and look over etc, i then put in the back of a van strapped down as you would normally and got the bike out the other end and filled up with fuel and off I went, almost straight away it was bogging like it was struggling for fuel/air but again this didn’t happen when I test rode earlier any ideas please guys I’ve got a sleepless night on the way TIA Foy
L1 750
Was the engine cold before you started it and test rode it?
Where did you get the fuel that you put in it when you got it back?
There are a lot of variables here...
1. Bad gas. Drain the tank, refill with gas from a reputable station.
2. Check to make sure no connectors/wires/plugs broke or came off during transport.
3. Pull the plugs and see what they look like.
4. Do a fuel flow test to make sure the fuel filters aren't clogged.
5. Pull the air filter, make sure it isn't gunked up from transport.
  • Like
Reactions: TwistedMister
