1 - 9 of 9 Posts
I need to remove the rear blinker cover, and I took the screw out, and it doesn't budge. Does anyone know how to remove it? I don't want to pry on it, or obviously break it. Anyone help me????
Thanks
Thanks for the help!
The lens cover has plastic interlocking tabs on the top and side of the blinker. They are hidden by the tail side section. Remove the blinker with the left or right tail section, then remove the blinker from the tail section and bingo the cover can be removed. 3 plastic center lock rivets, 1 phillips screw, turn signal wire and cowl latch cable ( left ) hold each section on.
Thanks a bunch! Is there an easier way to just remove the bulb? I tried to get at it from under the pass seat, but no dice!
Ball-peen hammer..
remove the tail section.. very easy.. I forgot to mention remove the seat.
You might wanna ask trakmaka. Seen his pics???
Discussion Starter #9
Way not nice. But nice custom work on the new bike!
1 - 9 of 9 Posts
