1 - 15 of 15 Posts
If I fit the Akrapovic megaphone slip on to the L8 and I don't put a fuel controller or change any mapping will it work ok without causing any damage to the motorcycle. According to STG and Revzilla, it does not and Akrapovic slip ons are designed especially to not require any mapping changes. Is that the case, or is it just information meant to help slip on sales?
My advice would be to bring it to your local dyno shop and pay for a few pulls with the sniffer in the exhaust to verify the AFR is safe.
With the L7 and later the slip-on is just a noisemaker because the catalyzer and SET valves are all left in place. It only minority changes the exhaust flow so its not going to make much of a difference if you don't adjust the fueling and reflash the ECU
In stock trim the L7 and later are ECU restricted and come with fueling on the lean side, so there's alot of performance that's restricted from the get-go. An Akrvpovic slip-on will certainly look much nicer than stock, but its not going to alter performance much or do any damage to the engine if you do adjust the mapping or ECU.
Hand-Eye Coordinator
Any slipon that leaves the CAT in place does NOT result in a need for fuel adjustment. Any exhaust mod that removes the cat, fuel adjustment is RECOMMENDED. People will decry not remapping in that case because of "muh valves will overheat," but it's false on modern engines. Your power curve will look like a bag of smashed assholes, though.
Uggggh! I thought I read K8 not L8
Senility is creeping in :smash
OP,follow the advice of the non-senile members above :crying
Senility is creeping in :hammer
:lol :thumbup You'll be here in October you said? Perfect camping season with the pretty fall foliage :crazy
Discussion Starter #10
Thanks so much. I fitted it last night, and it sounds and looks great and weighs next to nothing. I really appreciate your input, because is backs up what the various vendors told me. Thanks for your knowledgeable response. Let me see if I can figure out how to put a photo on.
Discussion Starter #11
Why did people used to talk badly about this forum. It seems pretty darn good to me.
They're all the former members that have been banned from here and are still butt-hurt about it ...90% are on gsxr.com ;)
1 - 15 of 15 Posts
