help
i need the diagram that shows the air line hook up points for a pingel eoa any help is
appreciated thanks for the help
JIMMY
The airline should go from the bottle to the electric valve to the air kill to the cylinder (Actuator).
Your fill line should be between the bottle and the electric valve.
Good rule of thumb... Keep the electric valve within 18" of the cylinder.
Hope this helps!
-Dave
THAT HELPS ALITTLE ALL the lines are cut to lenth
was hooked up before does any one have the picture from the diagram to post or send it pm
Hey dont forget one of those lines should be 6 inches longer than the other just cant rember which 2 lines there are supposed to be maybe someone else can help....damn alzheimers
