1 - 2 of 2 Posts
i dont remember where the post is. so ill ask again. this mixture adj., exactly where is it at? i know i have to drill out a plug, but dont know where this is. also, do i have to sync the carbs at the same time? is there an easy way to do this without buying special tools?
there should be a coper looking plug in the bottom of the carb with a small hole drilled in the center of it. That is it.. I can not do any better then that since i have only done it once like 8 months ago... lol
You should sync the carbs again if you are going to adjust your fuel...
1 - 2 of 2 Posts
