Gday to you all,
i need help in getting some Air filter pods for my 85 gixer750 i have 36mm cv's from 88gsxr i have tried k&n no-ru2922 which are duel striaght type but it hits the frame, i would like to put on a tapered duel filter or single but i cant seem to find any and have seen pics with them fitted to some bikes. Could anyone that has them fitted please give me a part no for them.
many thanks
damige
Damige,
Have you looked into the use of the single carb filters??? K&N and UNI both make these types... Cleans the area up nice saw a bike with some in place last weekend.
They are angled away from the frame, so, you should be able to get them on the end of the carbs and fit into place with no problem.
Also I use the K&N's you are using and I do not have the clearance problem you have as far as the frame being in the way. Check and make sure you have your carbs seated good, and the filters on
completely.
Good Luck,
JDB1371
