I did as the manuel says to do and adjusted the clutch lever. I got on to ride it and it seems as if the bike is harder to steer to the right. The only other thing that I did to the bike was take the extra chain slack out. Anybody have any suggestions?
only thing i could think is check the clutch cable and see if its tight around any steering componets. when you tighten the cable it can also tighten up against anything in its way. if that doesnt work try loosing the cable and see if it goes away
