Hi all -- Anyone know who makes good adjustable levers for the 05 1000? The stock clutch lever is a little too far from the grip for my liking... I saw some years ago, but can't remember the company. Thanks! Also, has anyone ever put a hydraulic clutch on a Gixxer? Expensive I'm guessing.
CD
I was thinking you might be able to adjust he cable down wher it connects at the caseing. If you look it connects too a part that works like a shift lever. It connects with a number of gear teeth. I think you could loosen it up pull it off and move it in one tooth. That should gettet it closer to the grip and you might have to turn the clutch lever adjuster out some. I will be trying this soon too.
