That should be the correct kit, suzuki's do not use the same kind of box that the other manufactures do. I suggest you use stock plug caps, solid core wires, and increase plug gap to about 35 thou. instead of 28 or 30. If you don't have stock plug caps use graphite wires, and plug caps with no resistance in them. I have a set on my 92 1100 and they work great. The difference between the 2 kits is that the internal resistance of the coils is different. Hope this helps!!!!
