Wow, great progress! How did you modify the tank to accept the new endurance cap? Your paint job looks great man! How many hours do you have in the body? Curious as I'm contemplating doing mine. What did you use to bend up the fairing stay? I just bought a welder so I'm going to be fabbing new stuff next season. Bike is going to look great when you're done.
Thanks Builder, the cap has a ring that goes inside the tank with threaded holes and the tank is sandwiched between the ring and the cap you see. So I just used the ring as a template to trace out what I needed to cut and also the drill the screw holes. Pretty simple tbh. Then just used a cut off wheel to cut the shape out of the tank. (The original tank has a metal drain tube that drains fuel from the original cap area, I cut that inside the tank and crimped it with pliers, I’m also going to cap the bung on the underside of the tank to be sure no fuel can escape)
I probably have about 16hrs into bodywork. There were 2 small dents in the tank and then the typical bodywork that needs to be done on the new stuff from airtech.
I made the fairing stay from 5/16 inch steel rod. The part that mounts the stay to the frame is made from some 3/16 steel plate I had laying around and the 2 pieces at the top where the mirror mounts would normally be that is also 3/16 but I made it to match the contour of the fairing to give it more stability (a cardboard cut out of the shape that fits the fairing then cut the metal to that shape and added a slight bend to it and it fit good) Mounted it all up and got it close to where it needed to be , and then bent and massaged the “wings” to get it all positioned correctly. Removed it and added some bracing from the rod and it worked out well. I was worried it would be a little to flimsy but once everything is bolted down including the side fairings it braces the upper really well and weighs a lot less.
